Turn Signals Bulbs?
Does anyone know the bulb size/# of the stock front and rear turn signal bulbs? It's not listed on the bulb itself and it's unlike one I've ever seen since the prongs are a little offset.
Mine are 1156 up front and 1157 in the rear.
Are you sure about the 1156 up front?  The pins are staggered I noticed and I thought the 1156 were straight across from each other.
I have an '04 and the pins are straight-across from each other = 1156.
Like this:
They're not the same a stock 1156 or 1157. There's a mod someone came up with to change this. I followed and changed mine to turn signal/parking bulbs. Went with led bulbs, but had to put in 8 ohm resistors to get them to flash slow. I like the look of more lights.
Omslaw
What does your screen name stand for? Outerbridge Miller Sefton law firm?
LOL.
Actually - rykstr is spot-on...
My name is Omar; I studied electronics in college...
It's a play on Ohm's Law
Did you purposely misspell it?
I did a little studying also, Masters in Electrical Engineering at General Motors Institute, now Kettering University
George Simon Ohm is twitching in his grave
