Twin Turbo busa???
redkat05
Dear spring....... HURRY!
Anyone see the latest 2 Wheel Tuner? There was a photo in there with a caption sayin somethin bout it bein twin turbo???
link?
i'll go to sheetz later today and pick it up and take a pic of it and the captioning
I havent seen the new 2WT yet, but I am guessing that is McCoy Motorsports Busa they built for the Metric TV show.
I have know Shane McCoy for many years. Their shop has turned out some sick R1/R6 customs. Imagine the irony when they pulled a Busa from the hat to build.
3D Billet
• “SUPERMAN†Front Reservoir Covers
Action Powdercoat
• Wheels - Translucent Red Powder coated center strips
• 3Front Brake Calipers - Translucent Red Powder coated
• Rear Brake Caliper - Translucent Red Powder coated
• Swing arm - Translucent Red Powder coated
• Sprocket – Polished
• Ducati Flower Drive Cover - Translucent Red Powder coated
• Sub frame pan - Translucent Red Powder coated
• Sub frame Under tray - Translucent Red Powder coated
• Rearsets – Polished & Translucent Red Powder coated
• Nitrous Bottles (2) - Translucent Red Powder coated
• Nitrous Bottle brackets (2) - Polished
• Frame Translucent Red Powder coated
• Clutch Cover – Polished & Translucent Red Powder coated
• Clutch Cover bolts - Translucent Red Powder coated
• Starter Motor Cover - Translucent Red Powder coated
• Engine Block – Polished & Translucent Red Powder coated
• Turbos – Polished & Translucent Red Powder coated
• Forks - Polished
• Triple Trees - Polished
• Clip-ons - Polished
• Levers (Brake and clutch) - Polished
• Twin outlet Turbo Airbox - Translucent Red Powder coated
• ANT Video Screen Monitors - Translucent Red Powder coated
• AIM Dashboard - Translucent Red Powder coated
• Side Panel Covers -Translucent Red Powder coated
• Gas Cap - Translucent Red Powder coated
• Pingel Shifter Brackets (2) – Polished & Translucent Red Powder coated
• Clutch Adjustment Cover - Translucent Red Powder coated
• Shift Rod - Translucent Red Powder coated
• Oil Pan – Polished & Translucent Red Powder coated
• Wave Rotor Carriers (2) – Polished & Translucent Red Powder coated
• Wave Rotor buttons Translucent Red Powder coated
AIM
• MXL PISTA Data logging digital dash board (Translucent Red Powder Coated)
APEX
• Tuning / Wiring / Dyno /
ANT Racing
• Dual (2) Rear View Cameras
• Dual Cyclops Monitor Displays (Translucent Red Powder coated)
AVON
• Venom-R Rear Tire 250/40R18
• AV59 Front Tire 120/70 ZR17
Catalyst Composites
• Custom Fabricated Tail Section (hand built utilizing R1 upper slope / MilleR rear upper / CBR 1000rr Seat vents)
• Custom Carbon Fiber Gas Tank
• Front Section (Custom Fabricated R1 Head light cut outs and Aprilia ram air vent)
• Billet Machined Gas cap
Cox
• Radiator Grill
Cyko Racing
• Custom ONE OFF 3D Billet Wheels (Chrome & Translucent Red Powder Coated)
• Cyko Rear bolt cover dish cone
BAZAAZ
• BPD II ECU Stand alone Engine Management System
Browns
• Chrome Swingarm
Dixon Customs
• Custom Upholstery and shaved seat covered in Ostrich skin
Galfer
• Front Stainless Steel Braided Brake Lines (Red)
• Rear Stainless Steel Braided Brake Line (Red)
• Clutch Stainless Steel Braided Clutch Line (Red)
• Race Modified Lines with inline mounted Line Coolers on all Braided Lines
• World Super bike Front Brake Rotors (Show Polished with Translucent Red carrier inners and carrier button mounts)
• Race Wave Rotor Brake Disk
Gator Customs
• Complete Painting, Bodywork Customizing and Gator Glass
• Painted Handle Bar Control covers
• Gator Glass Tail Section (transparent red and clear panels)
• Gator Glass Rear Tail light system
• Gator Glass Rear Turn Signals
• Gator Glass Tank Striping and Custom upper tank flanges
• One OFF custom side panels.
• Hand inlayed and flanged turbo side air vents
• Gator Glass Front Turn Signal System
• Gator Glass Clear Side Panel openings (exposes engine)
• Mesh Aluminum Covers Tail section vents (2)
• Mesh Aluminum Covers Side Panel turbo vents (2)
• Mesh Aluminum Cover Front Ram Air Vent
• Gator Glass front “Twin Turbo Nitrousâ€
• Combined Windscreen into front Upper bodywork
• Combined Headlight/covers into front Upper bodywork
• Gator Glass Front Upper bodywork (5 distinct “ghost†lighted areas)
• Combined R1 and Hayabusa Front Fender (SLIM low profile)
• Painted Rear Headlight and assembly covers
• Custom inlayed polished side panel covers (around exhaust pipes)
Greggs Customs
• Single Sided Swing Arm – Hand built single sided arm with trellis style hand fabricated rails (Chromed and Translucent Red Powder coated).
• Compressed air tank system built swing arm.
• Custom Frame – Hand built frame. Factory frame spars were separated and hand built trellis frame spars were built and incorporated into the frame with machined junction points (Chrome and Translucent Powder Coated).
• Balled Milled Rear Frame Spars
• Custom Ducati Rear Hub drive assembly
• Custom Mounted Brembo rear brake setup
K & N
• Air Filters (Twin w/ Chromed cap covers)
Koenig
• Low Profile Oil Pan (Polished & Translucent Red Powder Coated)
McCoy Motorsports
• Custom ONE OFF Adjustable Sub frame (Chrome)
• Custom “THUMB HAMMER†Throttle side nitrous purge/activation switch
• Clutch Oiling System with Stealth Mounted Oil Cooler
• Air Kickstand –Custom switch activated Kickstand
• Custom Designed Paint Scheme
• Custom One off seat pan
• Custom Radiator System
• Custom Radiator Overflow Catch Tank (Chrome)
• Custom Camera Frame Rail Mounts
• Fairing Side cover panels (Translucent Red Powder Coated)
• Stainless Braided Air line hoses
Motec
• Air and Pressure Data sensors
MPS
• Air cylinder – Integrated into air kickstand
Naarden
• Hayabusa “DRAG LINK†Lowering Link System
Nitrous Express
• Sport bike “WET†Nitrous System with Carbon Fiber Solenoids
• Purge System with Carbon Fiber Solenoids
• Dual (2) 1 lb. Nitrous bottles (Translucent Red Powder Coated)
• Dual (2) Billet Bottle Brackets
• Custom Fabricated Nitrous Bottle Fill up junction point
NO Magic Neon
• Hyperstrip LED System
• CL Pods
• Extreme Step Light Bars
• Micro Magic LED (Gator Glass)
• Wireless Perimeter Remote
Performance Café
• Complete Engine Build
Performance Coatings
• Turbo Exhaust Pipe HIGH Temperature Coating
PINGEL
• Electronic Shift System
• Digital Ignition Kill (UP / DOWN) box
• Shift arm mount system
• Chrome Dual (UP / DOWN) handle bar shift switch
Sport Chrome
• Magnesium Chrome Valve Cover
• Chrome Frame (4 piece)
• Chrome Sub frame
• Chrome Starter Cover
Techmount
• Video Screen Display Mounts (Chrome)
Trac Dynamics
• Race Valve and Lowered Front Fork System (Show Polished)
Tricky Air
• Hayabusa Rear Air suspension system
• Solenoid Air Compressor pump Setup
Tsubaki
• Nickel Plated 152 Link Roller Chain
Velocity Racing
• Custom Hayabusa Twin Turbo System
• Twin Outlet Turbo Airbox (Translucent Red Powder Coated)
• Clutch Cover and Clutch System (Polished and Translucent Red Powder Coated cover with custom red bolts)
• Modified Garret GT Turbos (Translucent Red Powder Coated & Polished) 250 HP each (2)
• Dynamic (Raked Front End) (Polished)
• Custom Twin Outlet Exhaust Pipes (Jet hot coated)
Vortex Racing
• Hayabusa Rearsets (Chromed and Translucent Red Powder Coated)
• Shift Rod (Translucent Red Powder Coated)
Walbro
• Fuel Pump 340
YMS
• Billet Machined Handle bar Grips (Anodized Red)
• Billet Machined Bar Ends (Anodized Red)
I would sell my first 14 children to have the KNOWLEDGE of how to do somethin like that! I would gain more satisfaction out of having the skills! Tell the builders "In the words of hayabusa.org
It looks like comeone mounted a couple of etch-a-sketches on those bars. Sorry, that was the first thing that came to mind....
(redkat05 @ Jan. 18 2007,16:56) I would sell my first 14 children to have the KNOWLEDGE of how to do somethin like that! I would gain more satisfaction out of having the skills!
I talk to Shane several times a week. I will pass that along.
If I am not mistaken, that 2WT will have his personal R6 in it as well.
I have seen this R6 in person in November at Deals Gap.
Nice bike, but it looks more like a Yamaha R-something than a Suzuki Hayabusa. It is a nice custom motorcycle, however....
(basscrazy @ Jan. 18 2007,17:08) Nice bike, but it looks more like a Yamaha R-something than a Suzuki Hayabusa.  It is a nice custom motorcycle, however....
Before I saw the finished bike, I expected some R1 touches on the finished bike, after all, www.tobefast.com are know for Yamaha customs.
