under cut tranns ??
If you're beating on it, 2nd gear becomes unfriendly from what I hear all the time.
Not true. 300hp to the wheel for the last 10k and no problems, stock transmission. I believe most problems arise from improper shifting, resulting in missed shifts. Which inturn starts the wearing away of the dogs.
bought mine used, dunno if i shift improperly, or if the other guy did, but second gear kicks out occasionally under hard acceleration.
can i just use the 08 gears since they are already under cut.
The gears will not interchange. You might be able to swap a complete transmission. The shafts in the gen II are larger.
Sent from my iPhone using Tapatalk
I could be wrong. I know the output shaft is bigger. I also know there are other changes internal to the gear pack.
My friend put a GENII transmission in a GENI motor. He said there is about a hundred thousanths difference.
I think he shimmed it somehow.
I can't be specific, but he said that it's not a direct swap.
