undertail question
haygix
got the top gun undertail.i was wondering if anybody can help me with the bracket for the licenses p...i have no idea how those pins work...pics will be nice , ty
If your going to use the bracket to mount the plate you are probably going to have to drill a couple of holes to mount it...
Not sure what you want to see? I didn't want to put the plate where mine is but circumstances required it. I just drilled into the undertail, put 3 screws in and sealed it up.
Pins that your talking about that comes with the
TG undertail are some sort of RIVET that needs special
tool.just use bolts with lock nut.
just installed mine today , did just like BigBSBusa did seems alot easier to drill into undertail then use 3 screws instead of a rivet gun.
They are cherry rivets/blind rivets/pop rivets, take your pick as to what you like to call them. You need a hand tool(similiar to pliars) for the blind rivets and a drill. Or use srews.
