arthur39
Getting ready to tune, I have unified fuel and ignition maps from a flashed Ecu, all short stacks. I've read in revealing ecu secrets ignition; that cylinders 2 and 3 will run lean. I'm relying on a power commander to tune the fuel (advanced map to add more fuel to cylinders 2 and 3) . Question being, where and how much fuel should I add to the center cylinders? All I could find on this topic is "ive got wideband bungs for each header,the middle 2 run leaner with all short stacks and unified ignition and fuel maps.I added 1-2% fuel to them" I'm assuming 2 percent fuel from 1000 to 5000rpm and 5000 to 11200rpm a 1 percent increase. Does this sound right? Any input would be appreciated.
Before Unified Maps
Based from Petrik "These are my findings related to how much bigger advaces for BankA (outer cylinders)
800rpm +4degrees
1200rpm +8degrees
1600rpm +3degrees
2000rpm +12degrees
4000rpm 0 degrees
6000rpm +5degrees
8000rpm +4degrees
10000rpm +1degrees
In the above it she area <4000rpm that caught my interest as there the main reason is very unlikely to be the cylinder temperatures.
Corresponding fuels are cyl 0/1/2/3
800 72/62/68/72
1000 72/68/68/72
2000 72/81/81/72
4000 86/89/89/86
6000 97/96/96/97
8000 103/104/104/103
10000 97/94/94/97
Before Unified Maps
800rpm +4degrees
1200rpm +8degrees
1600rpm +3degrees
2000rpm +12degrees
4000rpm 0 degrees
6000rpm +5degrees
8000rpm +4degrees
10000rpm +1degrees
800 72/62/68/72
1000 72/68/68/72
2000 72/81/81/72
4000 86/89/89/86
6000 97/96/96/97
10000 97/94/94/97
