unrestrict 1, 2, 3 and 4? ( 6 to)
bo-gsxr
all the topics i have found when searching, are concerning topspeed. and then surgest JC mod, tre, Gpac or pc3rusb.
not sure what the pc3Rusb does, but ARE there not a simple sulution to get full powerpotential in all gears and still run difrent maps for each gear? or is it only that 5 gear map that will work(using a tre or so like) And what will work on a 2006 busa? what i "dream of" is a stock ecu whit no restriction at all, and perfect map's for each gear.
you have as much power and you want until you hit the rev limiter in the first 5 gears. Its limited in 6th for top speed only.
a tre will take care of this.
well in some parts of europe the bike is restricted to 100 hp (i see your in denmark). i guess tre will take care of that but i am not to sure about it...
6th gear is restricted to a certain rpm.
Also, I believe the stock timing is slightly off. I've heard anyway
TRE will fix the 6th gear restriction by tricking the CPU that the bike is always in 5th gear.
A full exhaust system with a PC3 will fix ignition timing. If it really is off...
<span style='color:blue'></span>Any of you guys know where to get a custom map for the PC?
yoshimura has some basic maps, but for a custom one, you need to goto a dyno and have them make it for your bike. Every bike is different, so a custom one for your buddy may not work for your bike.
