Valves. The trick to adjusting the valves on a Hayabusa isn't the valve check itself, it's getting all the stuff off to get access to the valves. The actual process of using the feeler gauges and spinning the cams doesn't take long at all. But all the hoses, the injector bodies, etc. that need to get taken off so you can pull the valve cover are what eats up time.
As for the actual valve clearance issue... today's high-performance sport bikes (heck, all import bikes) have very reliable valve trains. The actual valves and valvetrain materials are so refined now and feature such good manufacturing, tolerance, etc. that unless you are a regular visitor to redline and do lots of hard rpm blasts your valves are likely to not wiggle out of spec. Heck, my last two sport bikes had a combined total of 90,000 miles. The valves were shim-under-bucket type. I checked the valve clearances every winter and never had to adjust one in more than eight years. I've done service work on other sport bikes ranging from gear-drive V-four motors (VFRs) to SOHC 8-valve motors (Kawasaki ZR7) and I've rarely found valves out of spec. If you treat your equipment nice, it goes around...
