Valve Adjustments
TURBO1320
safe than sorry its a performance bike treat it like one you will have less problems in the long run.www.1320strightliners.com
Most likely they won't need to be adjusted, but you should check as recommended to make sure.
Sounds like more fun than my Ninja. Checked and adjusted at 500, several tight, Checked again at 2,500, several off, probably due to my impatience the first time around, and I'll probably end up doing another one here before too long.
But luckily I adjusted the tappets with a screwdriver and socket, rather than replacing shims.
