onehelipainter
Ok manual says bring #1 piston to TDC , check to make sure timing mark is lined up. Why does it say to check clearance on #4 valves? I thought you check valves when piston at TDC= valves for that cylinder closed.
I'll open up my manual @ home tonight.still says nothing about checking #1 valves when #1 is at TDC
Ok, when No 1 is at TDC COMPRESSION stroke and firing, you check all 4 valves of No 1, check exhaust valves on No 3 cyl, check inlet valves on No 2 cylstill says nothing about checking #1 valves when #1 is at TDC
Professor Bryan...eve a tool belt for dramatic effect....
they are over due... bike is at 60k mi last insp,was at 24kHow many km are they due at is it 45 thousand km ?
Ok how do reset the Cct? This one has no bolt atView attachment 1601638 the rear.
I was @ work in a high school fixing stuff as usual. Just made a few minutes of time to explain the quick way to measure it out.Professor Bryan...eve a tool belt for dramatic effect....
Good video, bucket and shims have always kind of made me hesitate to do them....not now.
Every 24,000kms . . . so 48,000km is the 2nd check.How many km are they due at is it 45 thousand km ?
yes i could hear tickingIs it ticking?
I suppose sometimes they can tighten up too...I met a guy one evening who has a copper '99 bike and had it since new, it has 125,000kms on it and he checked the valves at each required interval and has yet to need adjustment.
