halcon blanco
hello! can somebody give a hand?
the clearance specifications for the intake valves are 0.14-0.23mm, and the clearance specifications for the exhaust valves are 0.18-0.24mm replacement shims are available in 0.05mm increments.....
1) the intake valve clearance for cylinder #1 is 0.26mm , the shim size is 2.85mm. what size shim would be required to adjust the valve to the proper specification range??
and, 2) the exhaust valve clearance for cylinder #1 is 0.16mm, the shim size is 2.75mm. what size shim would be required to adjust the valve to the proper specification range?
