harrisonj89
Good morning everyone,
I have done a fair but of research and pretty sure this is what it is but I'd like solid confirmation from those that have seen it.
2007 Stock Motor w/RCCs Stage one kit running 7lbs.
95 degree weather here in Texas and I took the bike out for about an hour or so. Came off the highway and the temp gauge was reading right under the half way portion as usual. I stop at a red light and it climbs slightly as I sit. It sits just above the half way mark and the fan kicks on and it stays steady. So far this behavior is normal to me without having the oil cooler anymore.
I look down as the light turns green and the bike is in the red with the light on. Holy crap! I take off and it drops back to normal and stays this way until I pull into my driveway and she climbs right back up and coolant comes out of the overflow.
No visible signs of external leaking, no coolant/oil mix and no white smoke or smoke of any kind. Just overheated out of nowhere. All fluid levels normal except the little bit of coolant that came out of the overflow when I pulled into the garage.
I just took the fairings off and I'm looking at the valve cover gasket* and there is residue in various spots. Now what I don't know is if it's dirt, grime or coolant slowly leaking through. So before I clean everything off I'd like your guys take. Thanks in advance!!
