OB_cbxchris
Stock valve spring pressure is 42 lbs. at the seat... the stock springs are 80 thousands from coil bind with a stock cam. My question is...Carpenter says his springs put somewhere between 68-75 lbs of seat pressure... these are automotive springs ....with the mild web cams its hard for me to believe you need that kind of seat pressure...50-55 maybe. You can run the stockers but I would rather not. Has anyone tried anything else or does anyone know of someone producing a spring for the bus. Carpenter also said aluminum retainers work fine but I`m going with APE ...better safe than sorry. All help is appreciated...hopefully Jay will comment on this.
