Valve Stem
Ham
Hey just purchased some 90 degree valve stems. I think i read some were that they are supposed to point to the right side of the bike. Correct me if I'm wrong. Thanks
Had to check...yep, mine were also installed facing right. Should come standard with the antilock brake bikes!
Troy
agree with above. work RH or LH but RH is best for airing up on the kickstand. Use blue LokTite on threads that hold stem in wheel...don't go too tight with aluminum--though it's a pretty hefty thread. Tight--maybe 7 or 8 ft lbs. That will seal it.
