Various Garage Tools defined
Devious
Onward through the Fog
Tools Explained for the beginner...........
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar
stock out of your hands so that it smacks you in the chest and flings your beer
across the room, splattering it against that freshly-stained heirloom piece you
were drying.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the
workbench with the speed of light. Also removes fingerprints and hard-earned
guitar calluses from fingers in about the time it takes you to say, "Ouch...."
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until
you die of old age.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of
blood-blisters.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It
transforms human energy into a crooked, unpredictable motion, and the more you
attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to further round off bolt heads. If
nothing else is available, they can also be used to transfer intense welding
heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects
in your shop on fire. Also handy for igniting the grease inside the wheel hub
you want the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles,
they are now used mainly for impersonating that 9/16" or 1/2" socket you've been
searching for the last 15 minutes.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you
have installed your new brake shoes, trapping the jack handle firmly under the
bumper.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering an automobile upward off of a
trapped hydraulic jack handle.
TWEEZERS: A tool for removing wood splinters and wire wheel wires.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill
bit that snaps off in bolt holes you couldn't use anyway.
TWO-TON ENGINE HOIST: A tool for testing the tensile strength on everything you
forgot to disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large prybar that inexplicably has an
accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a drop
light, it is a good source of vitamin D, "the sunshine vitamin," which is not
otherwise found under cars at night. Health benefits aside, its main purpose is
to consume 40-watt light bulbs at about the same rate that 105-mm howitzer
shells might be used during, say, the first few hours of the Battle of the
Bulge. More often dark than light, its name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids and for
opening old-style paper-and-tin oil cans and splashing oil on your shirt; but
can also be used, as the name implies, to strip out Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power
plant 200 miles away and transforms it into compressed air that travels by hose
to a Chicago Pneumatic impact wrench that grips rusty
bolts which were last over tightened 50 years ago by someone at Ford, and neatly
rounds off their heads.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you
needed to remove in order to replace a 50-cent part.
HOSE CUTTER: A tool used to cut hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a
kind of divining rod to locate the most expensive parts not far from the object
we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard
cartons delivered to your front door; works particularly well on contents such
as seats, vinyl records, liquids in plastic bottles, collector magazines, refund
checks, and rubber or plastic parts. Especially useful for slicing work clothes,
but only while in use.
DAMNIT TOOL: Any handy tool that you grab and throw across the garage while
yelling "DAMNIT" at the top of your lungs. It is also the next tool that you
will need.
EXPLETIVE: A balm, also referred to as mechanic's lube, usually applied verbally
in hindsight, which somehow eases those pains and indignities following our
every deficiency in foresight.
--Wag--
(Devious @ Jan. 09 2007,13:24) DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly-stained heirloom piece you were drying.
I need to test that out. "Honey?!! Where's the checkbook. I need to buy a drill press!"
(Devious @ Jan. 09 2007,13:24) WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned guitar calluses from fingers in about the time it takes you to say, "Ouch...."
I'd already determined to get into a life of crime just because of this.
(Devious @ Jan. 09 2007,13:24) ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age.
Finally got tired of the spinning and put the rivet on the drill press which promptly flung it into the wall.
(Devious @ Jan. 09 2007,13:24) PLIERS: Used to round off bolt heads. Sometimes used in the creation of
blood-blisters.
Hence, my printless fingertips can be identified by all the little red spots.
(Devious @ Jan. 09 2007,13:24) HACKSAW: One of a family of cutting tools built on the Ouija board principle. It
transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
Actually, a straight line can be obtained for a moment or two. Just piece them all together and and call it a day. The origin of the nickname, "Hack," for us cheap bastids who do our own wrenching.
(Devious @ Jan. 09 2007,13:24) VISE-GRIPS: Generally used after pliers to further round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
If you keep workin' it long enough, the bold head will be small enough to just allow the part to slip of the now non-existant bold head. Voila! Part is removed!
(Devious @ Jan. 09 2007,13:24) OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of.
The wiff loves that smoky smell in my hair!!!
(Devious @ Jan. 09 2007,13:24) WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16" or 1/2" socket you've been searching for the last 15 minutes.
Now this is a good one. I have a penchant for just wondering who in the hail invented these things.
(Devious @ Jan. 09 2007,13:24) HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
Great excuse for a new paint job. Works every time!
(Devious @ Jan. 09 2007,13:24) EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering an automobile upward off of a trapped hydraulic jack handle.
In reality, a Paul Bunyan toothpick. Poke THAT one up the tailpipe of said car.
(Devious @ Jan. 09 2007,13:24) TWEEZERS: A tool for removing wood splinters and wire wheel wires.
Only if wielded by the aforementioned wiff and only if she has stopped laughing enough to hold still!
(Devious @ Jan. 09 2007,13:24) E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps off in bolt holes you couldn't use anyway.
That's okay. You wanted a new car/bike/tool set anyway.
(Devious @ Jan. 09 2007,13:24) TWO-TON ENGINE HOIST: A tool for testing the tensile strength on everything you forgot to disconnect.
Generally, you can actually get the car a few inches off the ground before you have a fallout.
(Devious @ Jan. 09 2007,13:24) CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large prybar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
Is THAT what that is? Whoa. I think I'm about to have an out of body experience, man.
(Devious @ Jan. 09 2007,13:24) AVIATION METAL SNIPS: See hacksaw.
More straight lines. More laughing wiffs.
(Devious @ Jan. 09 2007,13:24) TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
Good thing, too. I'd never get any light on my pasty-white skin.
(Devious @ Jan. 09 2007,13:24) PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids and for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
I just make Phillip get his azz over here and do the job himself.
(Devious @ Jan. 09 2007,13:24) AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts which were last over tightened 50 years ago by someone at Ford, and neatly rounds off their heads.
Very capable of putting a bolt ON more tightly than it is able take off. Permanent bolt setter.
(Devious @ Jan. 09 2007,13:24) PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50-cent part.
Nothing like a little reworking of a paint job or body work project!
(Devious @ Jan. 09 2007,13:24) HOSE CUTTER: A tool used to cut hoses too short.
The first tool I ever owned!
(Devious @ Jan. 09 2007,13:24) HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts not far from the object we are trying to hit.
Still a weapon but much more subtle these days. Technology imbued them with their own aggressiveness and sneakiness. Innocent fingers and thumbs have suffered greatly since. Very often transformed into the DAMNIT TOOL (see below).
(Devious @ Jan. 09 2007,13:24) MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard
cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
Also very effective at nullifying any warranty on said items.
(Devious @ Jan. 09 2007,13:24) DAMNIT TOOL: Any handy tool that you grab and throw across the garage while yelling "DAMNIT" at the top of your lungs. It is also the next tool that you will need.
The most effective such DAMNIT tools create holes in the walls and the ultimate in effectiveness for such tools renders them irretrievable. Golf is recommended as a final solution.
(Devious @ Jan. 09 2007,13:24) EXPLETIVE: A balm, also referred to as mechanic's lube, usually applied verbally in hindsight, which somehow eases those pains and indignities following our every deficiency in foresight.
Must be used with care in the presence of some individuals such as Poindexter, Melvin and little kids.
I do a lot of wood working, and most of us have a table saw. A very hungry machine that loves fingers or throwing wood back at you! Loved the drill press, So true! Now after so many years I use ten clamps on a 6 inch piece, and still pray it doesn't come loose and take out my beer!
