velocity fuel filter
busa2001
what is a good replacement fuel filter for the velocity stage two street kit? need to replace the stock plastic part...
As I was having difficulties with Velocity fuel filter I decided to use the Stock fuel filter instead so I re-installed it inside the tank .
Go get a Fram g3727 filter. It is a little larger, but a good filter. It will also require a couple fittings in each side of it. Barry
