Velocity Stack
HayabusaMax1340
Hello to everyone.In the mean time i worked on my bike on ecu reflash and i put it in power commnder pc3 and my bike now goes like hell :)
Sound of the machine is like sound from hell to :)
I want to do it some modification on engine and what you suggest to me?
I found information about v stack by GSX R 1000 all of them of short kind give more power about 5 hp.
Is there anyone who was done this mode?I need Dyno results from this settings (v stack)
I thinking about vince&hines headers on my R77s.o. yoshimura.
Same question here.Is there anyone who worked on this and if he has dyno results also.
:welcome: to my thread :thumbsup:
is it me or does none of this post make sense?
"In the mean time i worked on my bike on ecu reflash and i put it in power commnder pc3 and my bike now goes like hell "
have never seen 5 hp gain just from stacks use the editor junk the pc buy fuel learn to ride then worry about the little stuff
As for the velocity stacks on my gen II.. I was instructed to get 2007 gsxr 1000 stacks and install them in my bike with the set up I am running that would complete the set up. I was told it's not so much for the horsepower gain but in fact for the throttle response.. I will say no notice of low or mid or high end loss or gain but more throttle response is defently there.
These few post about all short gixer v. stack I found on psihobike site
mrturbo1300r
Senior Member
picked up 4 in the mid range and 3 on top w short stacks and a race filter
Re: 08 busa short stacks or stock?
I picked up 5whp and a tenth in the 1/4 mile. I also picked up 2 mph . throttle responce down low also picked up and felt a lot better
put all short in my 08 and picked up 4 hp.
The engineers at Suzuki Mr. YenYanYo & Mr.Pull You Yoo Yoo
Designed the motor too use 2 short and 2 long V Stack for a reason.
I'm not an engineer but I did stayed at a Holiday Inn once :laugh::laugh:
As for his posts being hard to understand I do believe the Gentleman is from Serbia, thus, I assume, English is a second language.
This should not pose too much of a problem as many Americans have not mastered it as their first. (ZING....!!! :moon:)
cheers
ken
I did all factory short stacks because it was a cheap swap. I like the response but I don't know if it came from that, I made quite a few changes at once. Hope this helps...
I bought all four long stacks,i want torque instead of hp.May have to redyno cause using a different air filter now.
I run four long stacks. I wanted more midrange grunt, rather than just top end speed. I can honestly say that there is a difference, especially with the ECU flashed to match it.
Can send them out if anyone needs them.
:easy: Buy: SuperFlare Velocity Stacks for Suzuki Hayabusa - Factory Pro | Pashnit Moto
hate to bring up such an old thread but for the 08+ busas are they supposed to come 2 short 2 long? I see no difference in mine and they are all about 2-3 inches up from the airbox. If they are supposed to be 2 and 2 would that make the switch from 4 long to 4 short more noticeable?
