Vortex Frame Sliders!
javie
Hey guys I finally got my vortex sliders in (took 3 weeks! -_-) and I have no clue how to drill the holes in, anyone else do the install? I saw a walkthrough on the boards a few weeks back but cant find it for the life of me
Quoting Ibified. The rest are gone.
"One VERY important thing to do is to drill the fairings while they are on the bike!  This is how I did it:
1) buy a bolt that will screw into the motor mount.
2) grind the head off of the bolt and grind it to a point
3) screw the bolt into the motor mount hole with the pointed end out.
4) put the fairing back on and gently tap around the pointed bolt until you get a good solid mark on the back of the fairing.
5) dtill a 1/4" pilot hole through the fairing on the dimple that the pointed bolt put in the fairing.
6) (and this is where i differed from everyone, i think) Get your hole saw and remove the pilot bit from the center, and install a longer one.
7) Put the fairing back on the bike and slide the pilot bit into the hole and into the motor mount.  The threaded hole will act as a guide that will keep the hole saw at 90 degrees in relation to the hole, which is what you want.
8) proceed slowly and drill the hole out of the plastics.
9) use a rat tail file or dremel to smooth off any rough edges left by the hole saw.
10) install frame sliders.
11) do a happydance because you are now officially cool.
Get an allen wrench that fits the motor mount and grind it to a point as close to center as you can. Use it for the center mark.
If you drill the fairings off the bike....make sure you drill straight down regardless of fairing contour.
