Vortex rearsets-adjustment issues w/exh.
BigDiesel
I finally thru on my sweet new Vortex adjustable rearsets but i ran into a problem with fitment (bcuz I got big sasquatch feet n giraffe legs....
) on the brake side, the rearset wont drop into the lowest position at full rear becuz my TiForce pipe is in the way-the fitment I have now is much better than stock, but i think a lil further back would be even better.
on the shifter side, when I had the peg lowered to where I was really comfortable, the shifter would run into the kickstand and I could never get to first gear without killing the bike from tripping the killswitch on the kickstand...so now I have the lever adjustd a lil higher n it works ok, but if anyone out there has found that they can move lower with peg mounting running a custom kickstand, lmk I might go that route in the future
ok ok now, here's the pic
When you install the Vortex Rersets which switch do you need for the 08 BUsa the rs100 or the rs200, the difference is in the threading one is 1.0 the other is 1.25, anyone know?
Thx
