Warped rotor on my Kawasaki?
CBXRider
As I approach 28,000 miles I find that my front left rotor may be warped. On track stands the wheel will barely turn by hand but when I remove the caliper it spins freely. The pads are relatively new and in perfect shape. I’ve felt no pulsing under braking (it has ABS) or any other issue with them other than it’s harder to push around the driveway. Any ideas other than rotors? Some years back I switched to Arashi rotors on my Busa and they’re great. Could it be something other than a warped rotor? I suppose I could buy a micrometer but after removing the caliper which freed up the wheel, what else could it be?
Caliper pistons sticking
Well I thought of that but removing the calipers was easy, they slipped right off and went back onto the rotor just as easily. And I’d just used the brake before putting it on the stands. So, calipers easy on/off, pads fine and when placed back onto the left rotor and bolted w/o pumping the lever, the wheel is very hard to spin. As I spin it it becomes easier as it rotates and then back to being hard.
Sounds like a bent disc....
Maybe pull it off and put it on a flat surface......
Do you have to pump the front brake lever to get pressure?
With the bike on the stand, use anything like a run-out guage, set a screwdriver on a stool and slide it very close to the rotor, then spin the wheel.
You're not measuring anything, so all you need is something stationary, like a screwdriver, eye balled close to the rotor, and you will quickly see if it is bent, as the screwdriver will contact the rotor at the rotor's high spot.
That is the quickest way to tell without removing anything.
If you wanted to be precise, run-out guages are available with flexible arms(think desk lamp) and magnetic bases.
Stick it to the fork and move it into position, then when it's needle contacts a high spot on a rotor you will know just how far out it is by the guage reading.
Same type that you would use shimming a ring and pinion differential.
But, if you can feel the bend when you spin the wheel, you know the rotor is warped or bent anyway, so that hardly matters, lol
