Wego lll help
Bigboy Busa2
Too late to call daytona today. My tach signal is connected to #1 injector at ecu like the instructions say. Thinking of moving connection to the injector, maybe the signal is distorted from the other wires. Especially at idol you can see its jumpy. It is connected with a quick tap connector. The settings are as the busa setup on instructions. Any ideas, thanks
I did raise the debounce to 4 to try to clear the signal. No effect. But on real time data the rpm arm raise from correct 1750 and shoots to about 3500. AT IDOL. So need to figure out why. Thats what it shows on graph also. And tps on real time is jumping from 0 to 6 or 7 or 3 like a bunny rabbit. Note. The bike is steady idol the while time at about 1750 rpm. thanks
Making a little progress. Took signal wire off coil and used injector #1 signal. Rpm reading now but a little off. I heard this was common in the busa. Still going to call daytona Monday, has to be a reason. My other bike does the same thing. The only thing I havent moved, was thinking of using a separate battery just for wego to eliminate volt surge.
