I've never used a torque wrench when changing my oil on the drain plug, and I have used the same crush washer after 3 oil changes.
Now I pay the penalty
I stripped the oil pan a little. I have had 5 thread pieces come out of the drain hole and now I'm afriad that if I try to run the engine, metal pieces might float around to the wrong place and cause even more $$$$$.
Sooooo, A new oil pan costs $108.00. Oil pan gasket $8.65. Anything else you guys can think of??
Anybody want to sell a used oil pan, money's a little tight. As long as the pan is in good shape, used would save me money. Any tips for changing out the oil pan??
From now on its a new crush washer and 16.5 ft-lbs every time.
Thanx for any help.
<!--EDIT|Charlesbusa
Reason for Edit: None given...|1131569220 -->
Thanx for any help.
