shenanigans
Took the fairings off to install my new HID lights when I noticed that these plugs??? were leaking oil. What are these for any any ideas why they would be leaking? Thanks!
LOL
Ive stared at that photo for 5 mins and i'll be buggered if i can see anything leaking?
What are you looking out....?
I'll get my coat![]()
Those are not oil galley related, those are coolant plugs, similar to freeze plugs in a can, however you may a leak some where else. When you had your last service done, did they check the valves? If they did, they must have not reinstalled the valve cover correctly! One of the gasket on the valve cover most likely isn't seated correctly!
At any rate the bike is covered under warrenty, i would suggest bringing it to the dealer asap, so they can look at it!
