What kind of fan?
Cppr Busa
My fan has stopped working after 20k miles, I know it may not be the fan itself causing the problem, but I was thinking about swapping it out if there was a good replacement. Thanks
the usual change is the muzzy metal blades.
But why did your fan stop?
(VaBusa @ Jul. 09 2007,09:32) I have a Muzzy fan...very easy to install
+1
I was running above middle needle in 80 degree weather.
Now I'm running just under the middle point in 100 degree weather.
Sorry, don't have any real numbers for you...
(heavybusa @ Jul. 09 2007,08:59) the usual change is the muzzy metal blades.
Thanks for all the replies guys, I am not sure why it quit, I figured I would order a new fan and put that in first, then start trouble shooting from there.
muzzy and engine ice. T-stat/wiring would be a good place to start. good luck. muzzy here also
(rockadaous @ Jul. 10 2007,07:38) muzzy and engine ice.  T-stat/wiring would be a good place to start.  good luck.  muzzy here also
+1 !!! Those two items sure cured my heat problems this year!
