I was getting ready to install my battery tender cables and discovered the battery bolts are striped. Anybody know what size they are so I can replace them?
I think they are M6 and you should replace both the bolt and nut if the threads has gone south. Take the bolt with you to the shop where you will by a new one to make sure unless you can not determine the size.
yes I misspelled BOLTS... ie blots!! Parts guy at the dealership gave me new bolts and matching nuts!! The threads aren't stripped, the heads are both messed up, by the dealership!
