george b Registered Jul 29, 2011 #1 i ground a 16 & 22 and they work perfect for front upper thrust adjusters, but they dont fit the two rears. what size sockets do i use for those?
B busamike2012 Registered Jan 28, 2012 #3 i bought one from schnitz racing online it was around 70 bucks delivered to the house and works fantastic
GIXERHP ok, ok...just a wee bit Irish... Donating Member Registered Jan 28, 2012 #4 They should work on all the engine mounts, only the swing arm is different!
nabusa Registered Jan 28, 2012 #5 Actually the swingarm and the rear two mounts are the same. It is the front mount that is different, it is smaller then the rest.
GIXERHP ok, ok...just a wee bit Irish... Donating Member Registered Jan 28, 2012 #6 Well then i must have some special OEM Suzuki tool then, because the tool i have from Suzuki, removes all 3 outer and inner engine mounts!
