I just installed a 4-2-1 from Two Brothers. The bike seems to run fine except for a small hesitation down low. If I install a PC2 will it make a noticeable difference? If so what area(s) will it make the most difference. Low, mid, or high range? Will it eliminate the low end hesitation? I'm thinking about getting a PC2 but don't want to spend the money if the cost benefit ratio isn't there. So I guess the question is simply: is it worth the money when the bike is running ok to start with.
