(KanjiBusa @ Nov. 29 2006,19
) what i would look for - scratches, dents, rust, oxidation, paint chips, cleanlyness to ensure the bike was taken care of, if there are close to none 2 or 3 minor go for it. also check for uneven tire wear, if the tires look like they need to be replaced very soon tell him to knock of 100 or more for new tires, check the sprocket on the rear tire for rounded teeth.
miles- for myself i would look at less than 15-20,000
you can normally tell if it has been layed down right away by checking for scratches or signs of the bike sliding, peices that are most of the time left on after going down are, handlebar ends, stator on left side, gear box on the right, exhaust sides, check the rims of the wheels,
one thing that always helps is just turn on the bike, the busa makes a lot of weird sounds, but obvious, that doesnt sound right sounds you want to stay away from,
always before you buy, take it to a local shop try and make it suzuki, they can check it out and tell you all that has happened to it.
just use your judgement 7000> is a lot to spend
there are always people on this board that are trying to sell, this would be the best place to find something used because everyone knows everyone.
post pics when you get one
