I am trying to find out exactly what triggers the ecu to send the signal to the secondary fuel injectors?
Here is what has brought me to this question. I built a Turbo hayabusa (gen 2) 5 years ago. I run the Power commander v-pti, power commander Ignition, Power commander secondary fuel module and larger injectors. The car has ran perfect for the past 5 years. The last dunes trip the car started to lien out in the upper Rpm's. I assumed a sensor went out or perhaps I lost the tune? I reloaded the tune and swapped "Ap sensor, iap sensor and cam sensor" no luck. Car has no codes it will just lien out in the hire Rpm's under a load. I took the car to my dyno tuner that did the car originally. He verified the secondary injectors where not firing. They have 12v but not getting a signal from the ecu. Called powercommander and they said they only modify the signal from the ecu. So if no signal from the ecu than their fuel module does nothing. I tried taking out the powercommander stuff and the same thing. Now I am back to thinking it is sensor or ecu....So I bought another 2008 hayabusa motorcycle to play the parts swap game. I switched the ecu and every sensor.. So I though it had to be my wiring grounding out and I re wired the computer....Still the same problem. Please any help with my question: what sensors or parameters triggers the ecu to send the signal to the secondary fuel injectors?
