whats are good mods for a tall rider?
SNakez9
Hi all,
Im a somewhat taller rider, at 6'-3", can anyone recommend some good mods to help with wind resistance and comfort??
Thanks in advance!
Adjustable Rear Sets For Sure...I'm 6'4 and that make a world of difference
A lot of the guys get the Zero Gravity Double Bubble windscreen...
Nice Busa
get adjustable rear sets but make sure they adjust lower than stock.
risers for the front help.
tobin seat.
either double bubble or touring screen.
not much else after that.
dude that paint is bi**hn!
for the wind get a Double Bubble windscreen, Zero Gravity or Puig
for comfort #1 pick is a Tobin seat, period; then new foot pegs or if you can spend the $$ adjustable rearsets like mentiond above.
**also** adjust your hand-controls (brake/clutch levers) so that your wrists arent bent at funny angles to reach the levers, that will relieve alot of pressure, along with gel grips (foam is ghey n wears out quickly) and well-padded gloves.
6'3" here. As stated, for seeing the instruments you'll need a double bubble windscreen and install afteremarket pegs like GP pegs. Beyond mods you just need some muscle in your back, abs, shoulders and arms to alleviate the weight on your wrists. FYI, I'm very comfortable with stock seat, seat height and handlebar position.
GP Pegs:
1. Buell pegs! If you did nothing else this is the place to start. Alternatively you can get adjustable pegs from GSG or full adjustable rearsets from a a variety of places.
2. Genmar riser
(tie)I have both.
2. Helibars. Alternatively if you can still get them Cycle cat makes a really nice set of adjustable bar mounts that are just awesome!
3. Corbin or Tobin seat
4. ZG sport touring Shield
(tie)
4. Puig Sport touring shield. Alternatively you can get a Double bubble variant from either of the places mentioned that is a bit lower and more aero looking.
5. Some form of throttle lock/cruise control. I use a throttle rocker and I have a set of Throttlemeisters but I no longer use them. Still searching for the perfect solution myself.
WOW that paint, I have a DB and a set of heil bars it makes a world of difference my last step is the beull pegs that I'll be buying for the org!
Tobin seat will actually lower your sittin gposition but is more comfortable than stock seat..and looks good since they can be custom
I'm 6'8". You really don't want to lower your sitting position. It will scrunch up your knees. I ground down the stock foot peg rubber until the "nubs" were gone. The best mod I did was get a Zero Gravity Sport touring windscreen. The double bubble windscreen looks better but didn't raise the wind blast up enough for comfort.
i am 6.3 too,
done the buell modded pegs.
going to get a raiser for the front.
i will not lower my seat etc i need more leg space... lowering the seat will make it back to sq one.
Puig DB,Buel pegs and risers(soupy kit front and rear) made a world of difference for my 6'3" height!
