This is for the Gear heads who might know. Are there any ill effects on the engine oil pick up while doing stand up wheelies at high speeds and high RPM's? I was reading another post and I always wondered this because I have seen several other people that I know have spun rod and crank bearings and they are always riding stand up high speed wheelies. Does anyone know if this could be the cause.
I personally think it is a contributing factor in the spun bearings, the manuf did not engineer the engines to be at that angle for extended periods of time at high RPM's which could cause oil starvation, while light enough not to turn on the oil light it could have ill effects over time.
What do you all think?
