Is there only one nut to adjust the headlight on genII? Because when i turn the not on the lower left side of the headlight, it seems like it adjusts the low and high beam together.
Is there a way to adjust low and high beam separately?
No, both adjust at the same time. I am going to try and tilt the low beam with some kind of wedge spacer. the high goes through a lens and you can't adjust the lens.
