I put my filter after the pump before it hits the injector heads.no once i split the pumpi pull the clear now probably yellow piece out pump with screen on it,cut screen ou,reinstall,put pump in,a little silicone to create a good seal,let dry,and then i pull injectors carefully to get screens outof tops,reinstall,putpump on run longer line from pump to filter and then to rail and your done.
