where to launch at
Fire95Z28
Ok guys I never lookm at the tach. I just do it by sound. I have a stock ride height bike. Minor mods. I have no idea where to begin.
Where to begin what
...If your trying to introduce yourself... well then welcome to the board
I think what the guys are getting at is that it's sorta up to you. If your experianced, and you've been practicing then right about 4-5K is Ideal. If your like me and you just wanna take the clutch outta the picture then I launch at about 2K and simply flop the clutch and get to work on the throttle... Avoids the whole ON/OFF Clutch issues the Busa has. May cost in 60' times but out in the streets it simply allows you to get on the power within about 10' of moving without fuggin with the clutch... Works just fine.
What's rev talking about?
4-5K?
For Lunch?
? Dayum.......you've got a huge expense account!!!!!!
what launch....... i hear cape canaveral has been doing a fine job with the shuttle for the last few decades..... j/k
no seriosly Revilis put it best just use caution when trying to do it.
Start just above idle and then gradually work your way up.If it bogs, go up higher. I personally come out the hole at 6000rpms, but I have an extended arm.
I LAUNCH AT 9500 RPM..
YOU SHOULDN'T START THERE THOUGH. JUST LIKE YOU'VE READ. START LOW AND GRADUALLY GO HIGHER TILL YOU GOT IT DOWN.. IT ALL COMES WITH SEAT TIME.
