Thanks a ton, not a terribly expensive part. Bike tipped over while trying to change rear links . Really is more of a 2 man job, thank god I had my fairings off.
I should have better studied the physics of the whole ordeal. I had a jack under the shock mount providing mild pressure with the rear spools also gently resting on a rear stand. The bolt being removed dropped all the weight on the jack, 5 seconds later as I was setting the bolt on the floor she just tipped over.
