Which fairing (oil change)
NightCrawler
Love all. Trust a few. Do wrong to none.
Howdy ya'll. Imma gonna do mah fust ool chaing on da ole' Busa, an hadda 'lil questun for 'ya.
Okay seriously.
Does it matter which fairing is removed (clutch or brake side) in order to get to the oil filter? Or rather, would removing one give me better access to it than removing the other?
Right side, brake side Thats' this one ---->
Thanks all.
And PD, punch away dude ... it healthy to get it outta your system.
+1 right side. You may want to place some masking tape on the front portion of the fairing before you attempt to put the removed section back. It will assure you do not scratch your plastics when reassembling! It is also easier if you have one other person help align the panel as it seems like it takes 5 hands to do.
make a oil drain out of some tin foil so the oil wont go all over your pipes kinnda like a ramp thing . be careful i scratched my header a bit
trying to get the filter off the first time . wish i had put a rag there but i didnt and its gotta small scratch in the powder coat have fun .
