I just purchased a new EK ZVX 112 link chain..installed it last night and went to test ride it this afternoon and I'm getting a really bad "whining" sound out of the chain..can somebody possibly tell me what is going on?
I am getting a whining sound (for lack of better explanation) from the chain...the chain is not binding anywhere--I checked the travel by manually rotating the tire and watching the chain roll over the rear sprocket and route up to the front sprocket..it all looks like it is tracking straight..
I noticed the sound when I test drove it this afternoon after installing the chain...you can hear it well when riding and I can get up to speed and engage the clutch and it whines as the bike is slowing down...almost as if it is rubbing something but I have really looked and you can't see it visibly rubbing anything...
So, I put it back up on the stand thinking that maybe I have it adjusted too tight...
I re-loosened everything and started over...adjusted the chain EVENLY on both sides back to what I know is proper adjustment- I even went a little bit looser than what I had it adjusted the first time hoping that it was just too tight, but still the same results... I even measured my adjustment on the left and right tension adjustment blocks..they measure dead-on even at 1" from the front...
So, I am hoping you can give me some insight as to what might be going on...I know it is adjusted evenly, not too tight...so why would it be making the whining noise???
This is the FIRST chain I've replaced since the original (BUT NOT THE FIRST CHAIN I'VE EVER REPLACED...JUST THE FIRST ON THE BUSA)... what could be causing this? The original factory chain just had normal sound....so what am I possibly doing wrong??
Thanks in advance for any help...Chris
