Hi Guys,
I am curious, who has cut their pink wire lately for 2nd/3rd gear smoothness AND if so, has anyone had any problems whatsoever?? Do you recommend doing this? Is there any harm being done in the long run?
[This message has been edited by BullDog (edited 29 July 1999).]
I really would like to know this. I have had that wire between a cutter about 4 times and still can't decide to cut it. If you read that post on cutting the wire, it seems the thing to do. Please, anyone else done this??
Whoa guys - I thought cutting the pink wire on the US models caused a lean condition and Suzuki advised that engine damage could occur? Here is a segment of the info that is posted on THIS site under the MODIFICATIONS section of the home page of Hayabusa.org :
FROM SUZUKI:
Disconnecting this wire to increase performance is a common misconception.
If you were to disconnect the gear position (pink) wire on any Suzuki EFI motorcycle, poor performance and possible engine damage will result.
There is more - check under the modifications section.
