Who to extend my brake arm ?
C_Henry
got someone to extend my swing arm 4", but he just does the swing arm. Who can i get to just do the brake arm ?
Real easy just go to local GoKart shop or performance shop and buy two heim joints. Then go to local hardware store and buy small length of aluminium tubing that the joints can fit into after you tap the ends. BAM cheap and quick. Hope that helps Brian
<!--EDIT|busafreak
Reason for Edit: None given...|1125627949 -->
that's a good way too. I ended up just using a piece of flat bar aluminum, drilled two holes, routed the corners (dremel) and that was it. It worked for the gixxer, no adjustability though. trac dynamics sent me a new brake arm when I built the busa.
