Wide band AFR installation
My only recommendation is to find a decent welder that won't make a mess of the bung installation. Not that I would know...
Sorry, didn't made it clear
My bike is a gen 3 hayabusa that has ct megaphone in it with wide band o2 bung already
I want to wire it to switch power auxiliary that is my main problem
and I'm wondering if I need a relay or connecting directly is safe
You want it on an "ignition on" circuit. And wonder if it draws enough amperage to warrant a relay? I would say no, but I'm usually wrong...
There's a plug in the tail that Boost By Smith and a few others make a wired plug that will give you your switched power and a ground.
