Took stock screen out to tape same to get rid of vibration. When I removed the screen the rubber inner/nut piece came out also. It looked as though it was part of the screen and the "head" of it went between the screen and fairing? No problem with re-install, but had to remove inner dash part to get the rubber piece back into screen before sliding into position?
I have the rubber insert/nut through the windscreen before sliding it back into position? Manual looks like like I did it wrong? I'm thinking the rubber insert/nut should go from the outside fairing (head of insert on outside of fairing?),through hole and into the windscreen?
Confused? I know, only jerks do the work then look at the manual??
Any help readily accepted.
Thanks in advance.
<!--EDIT|PDBusa
Reason for Edit: None given...|1125526325 -->
Thanks in advance.
<!--EDIT|PDBusa
