Mikew777
Winter is here. I usually save any time consuming upgrades/mods for the winter because I won't be riding it in Ohio anyhow.
I have a 2014 hayabusa.
I just started with flashing the ecu using the harness from boostbysmith
Here is the rest of the to do list:
Cycle-Tek air shifter
Boostbysmith air shifter harness
Make some sort of bracket/mount for the CO2 bottle in the storage area
Brock's Ultra Clutch Mod
Dynojet map switch
Install Brock's track map to PCV
Oil change
Things to still order:
Brock's lowering strap
Second Hump (I want one with drag strip numbers and one clean for the street)
Vinyl numbers for second Hump
Can't wait to get it all installed!
Dynojet map switch
Oil change
