Well here's what I got
Stage 1 Velocity
213918 JE Turbo Pistons
80 spacer plate
Cylinder Studs and nuts
65 lb Valve Springs
H Beam Carillo Rods
Here's what Iam going to do
Ajustable Cam Sprockets ( I know should been done on last go round but I got tight on bucks )
Cam Chain
Undercut the Trans ( she pops out of 2nd )
Here's what I found on the teardown
All the Pistons have oil on them ( Like all of the valve seals are leaking )
Or the Rings did not cut in yet
On cyl 1 and 4 oil deposits on the back of the valve
Do you have any input
Thanks
Stage 1 Velocity
80 spacer plate
65 lb Valve Springs
H Beam Carillo Rods
Cam Chain
Thanks
