wiring a Valentine radar detector
spotrot
Because the Valentine uses a standard phone cord and jack for power, I ran a black cord from the extra connector near the signal lights. When not in use, it tucks out of the way and is virtually invisible.
Remove the right upper fairing (black) panel: 3 allens & 1 snap
Optional: R&R windshield for more access room
Cut a black phone cord to about 18â€￾
Solder or crimp a small spade end on both center wires (red and green on my cord)
Plug the red spade end into the side of the connector fed by the tan (+) wire
Check the polarity to make sure it is correct. On mine, looking at phone plug, left of center was green (negative) and right of center was red (positive)
Tape the phone cord to the signal light wires and brake hose cover
Turn the handlebars to make sure the cord is long enough and doesn’t bind
I mounted the detector on a Techmount stand (stem mount, from Jester)
Lesson: use water, not grease on o-rings to make inserting the stem easier
Here’s info from past posts on the harness connector:
“There is a connector (not used) in the nose next to the right of the speedo. Use a multi meter to determine which is power and ground and splice her in.
“That black connector is for euro models that use the turn signals as running lights.
“It draws power from the 10 AMP low beam circuit. If you overload it by plugging something in that draws too much load, you will lose your low beam when the fuse blows
Here is my escort...  It is powered by the same type phone chord connector, however I have it wired to a HARD transmitter (behind the inner plastic piece).  Suction cups hold it firmly in place.
(Powers739 @ Apr. 12 2007,19:35) Here is my escort...  It is powered by the same type phone chord connector, however I have it wired to a HARD transmitter (behind the inner plastic piece).  Suction cups hold it firmly in place.
Cool matching psi gauge...where did you score that?
Secondly, how do you have it attached?
I tried to set my whistler 1788 to the windshield like that, andalmost lost it from vibration-- you haven't had that prob?
Practice pulling and hiding it quickly. They're illegal to have in some states and guarantee you a ticket in all states.
No problem with it falling off, besides the HARD transmitter acts like a tether just in case it does want to come loose.
Any chance we can get some pics of the V1 in the techmount stand? Also, how does the techmount stem stand get installed/removed? Can someone simply pull it up and out? Or does it get bolted in somehow?
(dadofthree @ Apr. 22 2007,11:38) Practice pulling and hiding it quickly. They're illegal to have in some states and guarantee you a ticket in all states.
I never hide mine and never get a ticket... it works.
Any radar can be consealed if paired with HARD or similar system. RAM ait tube is a perfect place for that. just point it forward, plastics is no shield for radio waves. Laser guns is completelly different story.
(Vic_E55_2001 @ Jun. 12 2007,18:17) Any radar can be consealed if paired with HARD or similar system.  RAM ait tube is a perfect place for that. just point it forward, plastics is no shield for radio waves.  Laser guns is completelly different story.
True, but I want mine to be "easy on/easy off" since my V1 also goes in my truck.
mounted my radar/laser detector on solid home made bracket, no wiggle no vibration. CT legal, no need to remove here. wired it directly into fuse box.
My Nelson-Rigg CL350 tank bag should be here tomorrow so I'll test that out.
Anyone know if Radio Shack sells a cord that I can use to power the V1 ? I looked at it quickly and it seemed like a regular telephone cord didn't have enough pins....
escort using two center pins, so any phone cord will do. i`m not sure about V1.
Check original V1 cable, usually you could see trough connector.
Velcroed mine under right cover. It can be removed without taking cover off and is in a plastic box made to fit it. A box is also made for the Valentine. My Visual Alert display is mounted under windscreen.
Opps, wrong picture, I'll try again
