I’ve been hearing kind of a wah wah wah wah as I ride which usually means the chain has a tight spot. As I lubed the chain and checked for tightness in the links, the chain was fine but as I lubed it I noticed the sprocket has a slight wobble as it rotates. Never seen that before. It wasn’t loose so it has to be warped. The carrier was steady but the sprocket wobbles as it rotates. I wonder if it too was out sourced to China. With just under 13,000 miles I guess the wobble has worn the chain too badly to just replace the sprocket so new chain and sprockets will be forthcoming. Not sure I want to go with another OEM sprocket no matter where it was made so I’ll look to the aftermarket for some. Never happened on the Busa...
