CoryMckinstry
So I dumped like 700$ into my 02...tires tune up headlight oil change and spent 2 days fixing a wire problem in the light system..Got it ready for the yr..Today me and the wife took off on it and Got to the end of the spur and I began slowing down from 70 going through the geers.going from 5th to 4th I felt the shifter get real sloppy and was barly able to get through 2nd.I pulled off the road and shut it off.The shifter is now all sloppy but will go into neutral. I started it and tryed to get it home.I took off in first shifted into 2nd still with a lot of slop and got it into third.Thats all I could get out of it but mad it home. Im realy hopeing one of you guys might have an ideia as to what just happend.It feals like a retern spring broke becous the shifter doesnt retern to a normal pasition it just flops down to the lowest it will go?...
