Wont start
randl30
while I was riding down the road it just stopped running and will not start.RdRcr150 had the same problem in April,but do not know if he fixed the problem. I have a 2002 model. F1 system is ok. Put gas in the throttle body and it would start and run untill the gas was burned up. Tip over switch looks ok and does not have F1 problem code.May be fuel system(pump). How would check it.
Check for cloggin in the fuel lines, and be sure to doublecheck the fuel lines, both feeder and return for any obstructions.
Also double check the tip-over switch.
Easy way to check your pump is to listen to it when you turn the key on the bike. You should hear a healthy, high-pitched whine coming from the pump. If you don't hear that, take that sucker out and clean it up real good...taking care to replace the filter.
Also check for any frayed or nicked wires along the fuel suppply system. There is a possibility that there could be a ground shorting the system out.
