Hi there - first post.
Would appreciate some high level advice on the Woolich Log Box D-Can package. Does it come with an improved map/flash that can simply be used with everything else stock, just to improve over factory? Or is it only to be used with pro-tuners once installed?
My experience to date (on other bikes) has only been with installing a Power Commander to vastly improve over stock (with slip-on).
I can see, in the US at least that PCR6 is available for 2021+ bikes - should I source this instead?
I believe the Woolich set up allows fixing ISC (or whatever) for synchronising throttle bodies, which is of clear use.
Thanks a lot in advance.
