Y she want start back
HOOKDADDY
OK hers my story after 7 yr of no work last friday i found a new job with ameco yea me thank you Lord i can now tackel some debt right. no my girl decide to start when she want to she will start up fine in the am but when i clock out. its like who will push start me today
I'de start with the battery.
Eliminate simple things first.
A weak battery can cause all kinds of gremlins.
Go to an auto-parts store and have them test the battery.
Even if the battery is new, or not that old, it's still the best place to start.
If it is the battery, and the problem returns, then you obviously have something draining the battery.
That could be many things, so don't jump that far ahead yet.
wow ok but in the mean time is thir away to test the other componets of the charging system oh yea thanks
+1 on start with replacing the battery after seeing if it's still good.
We carry Yuasa's if you want a traditional lead acid.
thanks for the info i will try the sprocket again and the part store claim they cant test a motorcycle battery
A nationwide parts store, like Autozone or Pep Boys, should be able to test a battery. Perhaps the employee can't......
take seat off put voltage meter on the batt....leave it on and watch to see if it is dropping....you may have a drain on the system if you have added electrics at all.
yes viperwhite i have amp and speakers and leds in the airducts got the sprocket on thanks for that the part store needs the amps the they do not appare on the battery to test it so i look the itand called the c.service #that cant tell me nothing wow right its a WPS battery anyone heard of them b4
