Here we go:
Engine/power related:
Counter-balance shaft removed and lot of time spent on lightening and balancing crank.
Stock rods, Yosh Japan race cams and high-comp (12.8) pistons, stock valves and springs inspite of 11,300rpm rev-ceiling. Heads ported/polished, extra pre-load spacers on the clutch, close-ratio gearbox. They use Motec (Australian, car based) computer for EFI/ignition and still use the OEM/stock single injectors. Flapper valve removed from airbox. Side-stand cut-out switch used for quick-shifter triggering. Cooling was a problem, they now use 2 radiators above eachother and adapted from car-use keeping it cheap, oil-cooler mounted behind top radiator and also a Yam R1 watercooled oilcooler is used. Titanium exhaust with Tri-Oval end-can. Outside/underside part of OEM clutch-cover has section cut out and flat plate welded on again for ground clearance. Race class rules there dictate use of simple unleaded pump gas.
They won their class at the Suzuka 8 hours (you know, the one race per year where some of the worlds best GP500 and WSB cracks fight it out with Japans top home boys) and when they pulled the motor down afterwards in this 203HP@11,000rpm form it still looked ready for another 8 hours.
Chassis/handling related:
Rear swingarm is from GSX-R750 Superbike kit, went right in and was shorter. Ohlins shock, different top-mount (new lug welded to frame) and new bottom-bracket and linkages as well. Front forks are Ohlins from GSX-R750 as well and Marchesini wheels too (stock front size but rear's a 16.5/6). Steering stem moved back an inch and tilted differently for stock rake and increased trail. Swingarm pivot point lowered in the frame 5mm and Yosh' own top yoke. Nissin 6 pot front brake calipers.
Tires are still a problem (there's nothing out there for a bike like this), riding it is definitely a challenge, topspeed at the end of Suzuka's straight at 179 mph is 2 mph better than GP500 bikes on same day and their #1 rider qualified just behind Haga and his WSB-spec R7.
Terry (too tall) Rymer from the UK rode it as #2 rider in the last race for the All-Japan championship at Motegi circuit (Honda's new home track - 2 ring Motegi) in the Formula X class (similar to US Formula Extreme I think) and came away impressed. He thought that it could possibly win a WSB round at a high speed track like Germany's Hockenheim because of the unbelievable speed in the upper gears. Terry is normally riding Endurance racing classes (think he's a multiple world champ there) on tackle that's just a bit below WSB machinery and was quoted "... but once it gets into 4th and 5th it's a bloody missile, just keeps pulling and pulling".
Think that's enough for now.
