Yoshi Engine management system
Witte
I was looking at getting one of these. It is said to be able to control fuel curve and and ignition timing in one unit. I was wondering if anyones used it. I would like to buy this instead of the pc3 and the pc3r. The yoshi unit is $500 instead of the pc's $300 each. Is it not as good as the power commander or is it just as good. What should I get.
it is the same as a PC3R (map even interchange)but you can add bigg$$$stuff to it like a 3 map switch and switch map in a second
